Machine Vision
Totem pole / open collector
Hi everybody. I'm trying to connect the iso out of IC3120 to an industrial continuous inket printer (coding printer), replicating a rotary encoder signal. The inkjet printer can accept either a totem pole signal, or an open collector signal (please see attached photo).
Can anyone help give suggestion on which wiring I should use? Thank you very much.
regards,
Karman
(3,607 Views)
I recommend using the totem poll configuration. The digital output from the IC-3120 is push-pull or totem poll. Check out the following references for more information.
What is the Difference Between a Line Driver, Open Collector, and Push-Pull Quadrature Encoders and ...
USER MANUAL: IC-3120 - See pages 9-14 for wiring configurations
Best,
Aaron Douglass
(3,545 Views)
Dear Aaron,
Thank you very much for the answer.
Karman
(3,540 Views)
