Machine Vision
Transitions in VBAI
Hi
we are using VBAI 2010 and a smart camera for a vision project. In VBAI we programmed a programm with some states which are connected by transitions. Now we have a question:
If there are several transitions between the state which are true which will be taken? Are there any rules about the transitions in which row they are checked?
greetings
Oliver
(4,189 Views)
If multiple transitions are true, the state diagram will do through the transition with the highest priority. You can set the transition priority by right clicking on the state and choosing Set Transition Priorities.
Christophe
(4,185 Views)
Hello Christophe,
is your solution from VBAI 2011? Because in the moment we are using VBAI 2010 and there is only Edit and Delete on right clicking.
Is this also available on VBAI 2010?
greetings
Oliver
(4,182 Views)
Accepted by topic author OZI
No, this feature has been around since we introduced the state diagram. Right click on the STATE, where the transitions initiate (not on the transition).
This option is available only when there are more than 2 transitions coming out of one state (not counting the default transition).
Christophe
(4,180 Views)
Hi Christophe,
I got it. Thanks a lot. Thats the solution
greetings
Oliver
(4,177 Views)
