Machine Vision
Trigger camera to acquire multiple images
I have a camera from Imaging Source and it captures just one image for every external trigger pulse. But I want it to capture 3 images. Is there any idea of how to do it ?
The datasheet for the camera DMK 23UV024
Steps executed so far:
  1. Generate trigger pulse from a datagenerator and trigger the camera
  2. Developed a LabVIEW program that can capture image on trigger
  3. I have two different images to be captured for one single trigger, since the camera captures only one image for each trigger, it will create a confusion as to which trigger image belongs to which one. How can I solve this problem.
  4. The idea is to capture 2 images based on 1 trigger pulse without any interference between the two images
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
(5,386 Views)
Accepted by topic author abikutn
With few exceptions, cameras give one image per trigger.  There are some cameras that let you set a value register to capture multiple frames, but you would need to have one of those cameras in the first place.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(5,375 Views)
