11-11-2008 07:46 AM
12-01-2008 07:50 AM
Hi Bannwart,
If I understood it correctly, you have two input trigger signals in your Vision application. Then you need to trigger the cameras if any trigger signal is asserted. Is it right?
How are you programming your application? Are you using the CVS default FPGA personality? The best choice for your application is to program the FPGA in CVS to implement your custom trigger. Please check the link below.
http://zone.ni.com/devzone/cda/tut/p/id/3261
Please let me know if you further questions,
Alisson Kokot
AE BRAZIL
