Machine Vision
Triggering Dalsa Linescan Camera & 1437 B/D & External B/D
S/W : Win7 64bit, LabVIEW 2018 SP1(64bit), NI-IMAQdx 18.5
H/W : Dalsa P3-80-8K40, PCIe-1437, Extension B/D
I want to use line trigger with encoder as in the attached example.
Reading the encoder confirmed.
We also used TTL / ISO / RTSI to receive external triggers. However, I did not receive a trigger.
What should I setup to receive and use a trigger?
(3,205 Views)
Hi side,
Were you able to solve the issue using a RTSI ?
Could you please explain and if possible post some code how were your triggering issues solved.
Will be great help.
Thank you.
(3,004 Views)
가장 좋은 방법은 acquisition software 2014 버전을 사용하는 것입니다.
(2,992 Views)
Seems like you are using the NI-IMAQdx functions.
But it should be NI-IMAQ for camera link.
Amit Shachaf
(2,986 Views)
  • IMAQ
  • IMAQdx
(2,976 Views)
I have succeeded in using "PCIe-1437".
However, it does not work on "PCIe-1433".
(2,893 Views)
