Machine Vision
Trying to sum IMAQ images into a buffer using pointers
I'm acquiring and co-averaging imagery very fast (too fast to write to a RAID system) and therefore would like to create an accumulation buffer where I simply sum the pixel values in a single buffer.  The key is, its too fast to allow me to use the IMAQ Image to Array function and then add arrays normally in LabVIEW so I was hoping someone might now how to use pointer arithmatic to accomplish the same goal.  Is there a way to do this without writing a C-language DLL?
(4,745 Views)
Vision Development Toolkit has Image Math VIs for this.  Can you not use those?
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(4,721 Views)
Thanks, I have not used this toolkit before but will check it out!
(4,711 Views)
