Machine Vision
Two basler camera
Dear NI,
I have two basler cameras and I have IN IMAQ software also ,
I need to stream both Basler cameras at the same time , I was trying with Measurement and Automation explorer(MAX) In MAX I can see the cameras streaming one at a time . But when I interface two basler and open two instances of MAX it does not show the two different streaming videos
but suppose I take one Basler and one web cam (inbuilt my laptop) and open the two instances of MAX then I am able to see output of both cameras simultaneously .
I need the same thing using two Basler which are connected to PC via ethernet port how can I achieve that?
rupesh
9716935137
(3,382 Views)
Hi rupesh,
How did you connect your basler camera to the system. Through Hub or directly in the PC.
Silver_Shaper | CLD
(3,372 Views)
