Machine Vision
USB CAN Compatible with RT Controllers?
We are looking at quoting on a system however it would include a identification of a automotive CAN module which I suspect will be much easier to identify with CAN interrogation, than with vision (black on black.)
The rest of the application would be traditional vision (VBAI), however I am not able to determine if a USB 8501 CAN module would be compatible with say an IC-3120 running RT. Also does the 3120 include vision deployment and Vision Acquisition or would these licenses still be required as I see it is bundled under industrial controllers, rather than vision systems?
Would there be any issues running a CAN LV VI under the "Run LabVIEW VI" step type without additional licensing?
Message 1 of 1
(2,585 Views)
