Machine Vision
USB cam stops working after first IMAQ session
I am using also the logitech webcam C250.
And this problem also occur when using windows explorer with the camera.
I think it is that the problem is a typical camera problem, not LabVIEW, not IMAQdx.
 I am working with Windows Xp, and Windows 7 64 bit.
Searching on the web, you will find many similar problems with this webcam.
Although, if NI can solve the problem I would be happy:
the old software NI IMAQ for USB can handle the C250 correctly.
Maybe they can solve it also for IMAQdx.
Cor van Leuken
The Netherlands
Message 11 of 13
(1,107 Views)
Same problem here.
Has anyone had any luck with this?
Message 12 of 13
(1,042 Views)
I have solved the problem: I am using another webcam, Logitech C270
I started a discussion with logitech, made a lot of changes to my laptop, and finally they send me a webcam C270 to test whether the problem would occur also.
It didn't, thanks.
so we have replaced all other C250 (16x) by C270
that webcam is even better, a higher resolution.
I am sorry for you that I didn't have a better solution.
Cor van Leuken
The Netherlands
Message 13 of 13
(1,039 Views)
