Machine Vision
USB3 VISION
Our company is to make the machine vision camera.
I would like to know whether our camera is compatible with usb3 vision or not.
Does NI MAX have the compatible checking S/W Tool about USB3 vision?
I know the NI has the compatible checking S/W tool about GigaE vision..
(4,673 Views)
The USB3 Vision standard itself is released with an accompanying set of device-side requirements that are necessary for a camera to be compliant with the specification. Furthermore, there is an exhaustive compliance test suite that is used for USB3 Vision logo certification that can test many of these requirements. You should contact the AIA (contact info listed in the spec itself) for details about this test suite.
Eric
(4,665 Views)
