Machine Vision
Unable to load XML file in NI-MAX for Allied Vision Manta_G 145B. IMAQdx v. 20.6
I try to migrate from LV2014 to LV2020. If I try to open Allied Vision Manta_G 145B camera in NI-MAX i get Error 0xBFF6901D "unable to load xml file". IMAQdx Version is 20.6 (RT + Dev). Basler Cameras work fine.
I have upgrated the firmware of the cam to the newest version, but it didn't help.
(1,994 Views)
I have installed IMAQdx 21.0 without success. A Manta-032B works without problems...
Any help or workaround is most welcome. Is there any way to load the XML file manually?
(1,968 Views)
Accepted by topic author p4keal
Finally, I was able to solve the problem. I do not know which of the two steps led to success:
  1. I renamed in folder C:\Users\Public\Documents\National Instruments\NI-IMAQdx\Data\XML the file avt_E0020006_1.44.xml.
  2. I copied the content of the folder PreProcessedCache from an IMAQdx 14.0 PC to the target PC.
Now NI-Max can open the cameras. The XML file has been recreated.
(1,953 Views)
