Machine Vision
Unvalid firewire error : Insufficient Resources ...
Hi all,
I am a seasoned LabVIEW developer, and I am working on a vision project with 10 identical firewire A cameras (AVT Guppy).
My HP workstation has 2 firewire cards :
- PCI 3-port (preinstalled)
- Added a PCI-Express 3-port card (Belkin)
I have 2 (powered) 6-port firewire hubs.
Each hub is connected to 5 cameras and to one of the firewire cards.
Each camera is recognized in MAX, and is configured to 400 Mbit, and to a video mode of 640x480, mono, at 15 fps.
This means (according to the firewire bandwidth calculator : 13% per camera).
So this is 5x 13% per firewire card = 65% load.
- No problem whatsoever for the preinstalled PCI firewire card :
(3,692 Views)
For the users with similar problems,
You can find the problem described here.
Kind Regards,
Wouter
National Instruments Belgium
(3,675 Views)
For users with similar problems,
Kind Regards,
Wouter
(3,671 Views)
Is it because of too many threads(double,triple and many..... post) u got confused and posted the same msg after an hour?
(3,667 Views)
Too many tabs open in Firefox....that's all....
Wouter
(3,662 Views)
