Machine Vision
Update for Vision Builder AI
I'm just wondering if you can tell me when there is likely to be an update/patch release for Vision Builder for AI 2.6.1.
During a system development late last year, through this forum, I was made aware of a 'bug' limiting resolution of the edge detection algorithm. As the system I was constructing was to perform extensometry on gauged wire samples, this was a real problem. Fortunately I was able to work around this limitation using pattern matching techniques, however edge detection would still provide a better solution.
I was hoping an update release, incorporating a fix for this bug, would have happened by now.
Any idea when one is likely?
Greg Shearer
(3,510 Views)
Hello Greg,
Unfortunately, updates to VBAI have not been announced yet, so I am unable to tell you what is being planned.  However, the bug reported is being worked on and a fix will be provided as soon as possible.
Allen H.
(3,497 Views)
Ok Allen,
Thanks for the feedback. I'll just keep an eye out.
Greg
(3,491 Views)
