Machine Vision
Using 50 pin I/Os on PCIe-1473R cameralink board
Hi, dear all,
I am wondering if there is the pinout map of the 50 pin I/O on the PCIe-1473R cameralink frame grabber.
Although there is a extension board could attach the card (http://www.ni.com/pdf/manuals/372736b.pdf), I wan to directly connect the 50 pin out instead buying another card since we just simply want to use the DIOs.
Thanks.
Best.
(3,470 Views)
I do have the same question !
can't find any related document  :'( :'(
(3,454 Views)
Accepted by topic author cychang0829
Because this is a proprietary connection meant for internal use with the specific I/O extension board, I am pretty sure the pin-out is not documented anywhere. I'd also have concerns about using the I/O directly as the circuits were not designed for direct use and may not have much in the way of protection against damaging the board like most external I/O signals have. There is a chance you could damage the board as a result.
(3,446 Views)
I am using this card with the connection board for a while (hundreds of tools in the field since 2012).
The FPGA card is very expensive. The I/O board is relatively cheap.
The I/O board has protections on the I/O.
It is fairly good design. We don't get many issues that make us change the cards in the field.
By design we are not connecting to the I/O on the FPGA board (I/O 0). That way we keep the FPGA card protected.
Amit Shachaf
(3,437 Views)
