Machine Vision
Using CVI and IMAQ, I use imaqDisplayImage and the image is out of sync, it displays the second half of the image as the front half and visa versa
Below is a striped version of my code. The card is the 1409 and I am using a Hitachi RS-170 camera
imaqSetupWindow (IMAGE_WINDOW_0_CONST, IMAQ_WIND_TITLEBAR + IMAQ_WIND_TOPMOST);
imaqSetWindowSize (IMAGE_WINDOW_0_CONST, IMAGE_WINDOW_X_SIZE_CONST, IMAGE_WINDOW_Y_SIZE_CONST);
imaqSetWindowPalette (IMAGE_WINDOW_0_CONST, control_val, NULL, 0);
imaqShowWindow (IMAGE_WINDOW_0_CONST, TRUE_CONST);
Position.x = IMAGE_WINDOW_X_POS_CONST;
Position.y = IMAGE_WINDOW_Y_POS_CONST;
imaqMoveWindow (IMAGE_WINDOW_0_CONST, Position);
// Open a session
err = imgInterfaceOpen ("img0",&Interface_ID);
err = imgSessionOpen (Interface_ID,
&Session_ID);
imaqSetupGrab(Session_ID, IMAQ_NO_RECT);
newimage = imaqCreateImage(IMAQ_IMAGE_I16, 0);
LOOP
imaqGrab(Session_ID, imagein, FALSE_CONST);
ret_val = imaqDuplicate (imageout, imagein);
imaqDisplayImage(imageout, IMAGE_WINDOW_0_CONST, FALSE_CONST);
ENDLOOP
(3,569 Views)
Hello Tzaj,
Make sure that you can grab the image in MAX correctly before you try grapping images in CVI. Then, see the example program on our Developer Zone (link below):
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/e6f87111578c409786256878007333ee?OpenDocument
Hope this helps.
Morten Jensen
(3,569 Views)
