Machine Vision
Using CVI to Read an AVI
I am trying to read an AVI in my CVI code, but it isn't working.  I am able to read the same AVI fine in a VI, just not on the C side of things.  Here is the code I am using:
	AVISession session = 0;
	session = imaqOpenAVI("C://MKX.avi");
	int error = imaqGetLastError();
	AVIInfo *info = NULL;
	imaqGetAVIInfo(session, info);
	printf("There are %d frames at %dx%d\n", info->numFrames, info->height, info->width);
The call to imaqGetAVIInfo returns null.  I made sure the path to the AVI was correct.
Any suggestions are much appreciated.
Shawn
(3,815 Views)
Have you tried "C:\\MKX.avi" for the path? (use backslashes instead).
-Christophe
(3,811 Views)
Whoops, that was an error in my code posting.  That was left over from trying "/" instead of "\\".
imaqOpenAVI returns 1, which I think means it opened it okay.  I also did a imaqGetLastError after the imaqOpenAVI and it returns 0.  I also added an error check after imaqGetAVIInfo and it comes back with: -1074395269 Null pointer.
Am I just missing something obvious with my code?
Thank you for the reply.
(3,740 Views)
Accepted by topic author shawnhunt
I haven't looked up the documentation for that function, but it looks like from the way you called the function (and also the error code) that you are passing it a NULL pointer. The function would have no way to return the info you asked for with the way you are calling it. I imagine it expected you to allocate the structure and pass it by reference.
Your code should probably be modified like this:
AVIInfo info;
imaqGetAVIInfo(session, &info);
Hope this helps,
Eric
(3,735 Views)
Ah, yes, totally my fault.  I was having a total brain freeze on that one.  Thank you!
(3,730 Views)
