Machine Vision
Using CWImaqViewer to display only failed part
I would like to show in cwimaqviewer only failed inspections (using Visual Basic .Net).
I think I should set the ImmediateUpdate property to FALSE and then use the Refresh() method to do the update when required.
The problem is that, although I set ImmediateUpdate = False after Viewer.attach, the image continues to update in the viewer!
What I'm doing wrong??
Simone
(3,290 Views)
Hi Simone,
It looks like you are doing things the right way.
Maybe some other piece of code is refreshing the display, is this possible ?
Kind Regards
FiloP
It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong.
Richard P. Feynman
(3,245 Views)
