Machine Vision
Using Imaqdx for an camera wifi
I use an camera axis207MW. I want acquire image with IMAQDX. I already use active'x but now I want to do image processing and It's more easy with IMAq and vision assistance. I know that FRC software component have his icons to control axis camera but how acquire image from a wifi camera with IMAQdx?
(4,646 Views)
Vision Acquisition 2009.11 or higher (http://joule.ni.com/nidu/cds/view/p/id/1524/lang/en) should just automatically detect the Axis camera and allow you to acquire from it.
Eric
Message Edited by BlueCheese on 03-23-2010 09:01 AM
(4,642 Views)
Thanks. I use this software but the camera isn't detected on the network when I enter his ip adress may be because the camera is on wifi ??
(4,610 Views)
What is the camera's IP address configuration? What is your PC's IP configuration? They need to both be in the same subnet for IMAQdx to discover them. Can you ping the camera from your PC?
Eric
(4,606 Views)
Yes. When I ping the ip camera on my pc I can see it.
(4,602 Views)
What is your IP addressing configuration (ip address, subnet mask, gateway) on both devices?
Eric
(4,579 Views)
