Machine Vision
Using Labviews 6i Limited Vision capability to capture frames from DT3132 Board.
I'm wondering if anyone has used Labview 6i Limited IMAQ VI's to
capture images from a Data Translations DT3132 Board? Is it possible
to quickly create an Application without purchasing IMAQ Vision ADD-IN
Module for Labview?
Regis
(3,485 Views)
Regis,
You have confused capturing and processing images.
The IMAQ drivers are used for capturing images using NI boards. If you are going to capture images using a different manufacturer's board, you need to find out if they have drivers for LabVIEW.
The IMAQ add-on toolkit is for processing images. With the built in tools, you can't really do any useful image processing.
Bruce
Bruce Ammons
Ammons Engineering
(3,485 Views)
