Machine Vision
Using Logitech Quick Cam to grab images.
I have been successful in using the Video for Windows VI (vfw example.vi) to grab an image from a Logitech QuickCAM 300 camera . I also have two other vi's which are for use directly with the Logitech camera. They are:
Quickcam_capture_frame.vi
and
Logitech quickcam_example.llb
However I have been unable to get either of these to work. I have enabled the ActiveX control in the VI server properties dialog box and do not have anything else using the Camera.
They should be straight forward to use but I can't seem to get them to work.
Has anyone used either of these VI's and if so have they encountered any problem which needed to be overcome to get the VI's to run.
Thanks, - Troy
(3,753 Views)
You may want to check out the Activex Control with LabVEIW examples at www.inventeering.com It is called INVENTvisionVFW.
(3,753 Views)
