Objective: I want to use the XC-75 camera with Labview/Vision/MAX to capture images that are singe frames. I also want to know the time interval (with uncertainty) between each frame.
I am using a XC-75 camera which allows me to set the shutter speed of the camera to one of the following: OFF, 1/125, 1/250, 1/500, 1/1000, 1/2000, 1/4000, 1/10000. The default setting is OFF.
Some initial questions:
1. The default setting is OFF. What does this mean, 1/60 sec?
2. Is there a maximum frame rate supported by Labview or the PCI 1409 card?
My understanding is that the IMAQ Grab Acquire will acquire every image that comes from the camera through the PCI 1409 card. Does the MAX software control whether or not the image captured is a frame or a field? How to I ensure it is a single frame?
I also want to know the exact time interval between images. I guess this is directly related to the shutter frequency. Is the time to open and close the shutter already accounted for or sufficiently small so as not to factor in?
The other option is to control the shutter using an external trigger (the camera uses a trigger shutter S-DONPISHA function). I was leaving this as an option only if using the manual shutter settings was not possible.
Thank you for your assistance.
