Machine Vision
VBAI Calculator empty function palette
All of the features have disappeared from my calculator step functions palette except for "Select a VI...". I've tried repairing VBAI, removing and re-installing, and the issue persists.
Any help would be appreciated
VBAI 2018 - Build 20180625200940 (32-bit)
(1,790 Views)
Accepted by topic author adam.hopkins
I think my palette file must have gotten corrupted. I solved the issue by resetting the palettes in LabVIEW back to the factory setting.
Tools->Advanced->Edit Palette Set... then "Restore to Default" in the resulting popup window.
(1,726 Views)
