Machine Vision
VBAI data logging from CVS to PC using FTP
I am trying to set up remote datalogging from a CVS to a local PC. The PC is running WinXP PRO SP2. I have set up th FTP service and it is running correctly. I can log on from any other PC, have all access rights (including write and create directory, which I have tested). However, when i set up the Datalogging step in VBAI 3.0 on a CVS unit, it does not work correctly. I enter the IP address, enter either anonymous login or enter a functional username and password. I even test the login with possitive response. However when I try to save the Datalogging step, the VBAI says that "The specified folder does not exists. Do you want Vision Builder AI to create the folder?". I click Ok and the result is "Vision Builder could not create the specified folder." and it does not save the step...
Does anyone have a clue where the problem is? The FTP service is working correctly (at least it works using a stadnard windows ftp console). I can even connect to the CVS using FTP... but it cannot set up the Data logging.
Martin
(3,256 Views)
Hello Martin,
This is a known issue which is fixed in VBAI 3.0.1.  You can download VBAI 3.0.1 from here:
ftp://ftp.ni.com/support/imaq/pc/vision/VisionBuilderAI301/
Let me know if you have any problems or questions.
Brad
(3,248 Views)
