Machine Vision
VBAI problem with calculator tool
Concern/tested with: VBAI2010 (build 2010 1014091017)
I have a problem when I use a calculator tool. The Pop-up menu (left clic of the mouse) is disabled when pointing on an item (inputs, outputs, operators...). So I can't access the options for that item. That issue is very problematic on a "forumla node" because it's impossible to add any input or output.
Do you have a work around ?
Can NI developpers please correct this?
thanks for your help.
(3,804 Views)
Accepted by topic author ExpertiseVision_UM
This will be fixed in the next version, but there is a workaround:
Close VBAI
Open the Vision Builder.ini file located here: C:\Program Files (x86)\National Instruments\Vision Builder AI 2010 and set the hideBDPopupMenus = False
Restart VBAI
-Christophe
(3,799 Views)
Thanks for your answer!!it works!!
(3,785 Views)
Is it possible to have the definition of each parameter of the file  'Vision Builder.ini'?
thanks
(3,755 Views)
