Machine Vision
VBAU Engine sometimes can't open vbai file
I've written a C# program as user interface. The program runs VBAI Engine. Sometiimes Engine can't open the vbai file. After restarting Windows 10 programs work fine again. Has anyone ID?
(1,272 Views)
After failing in loading that inspection file, did you try loading it from the VBAI interface instead ?
And by the way , did you check that the file wasn't already loaded (in another vbai instance) ?
Sami
(1,238 Views)
No, I did not try to open the inspection in Vision Builder after fail. But I always check if inspection is open in engine before I try to open. My program enters into catch thread: Another interesting thing. Sometimes I could not close. So, I have to kill every process named Vision Builder when my program starts. 🙂
private int SetInspection(string VBAIEnginePath) //Beállítjuk az inspection-t
InspectionInfo ActualInspectionInfo;
try
WriteLocalLog("Checking current loaded inspection path. " + VBAIEnginePath + " VBStatus=" + VBStatus.ToString(), false);
ActualInspectionInfo = engine.GetInspectionInfo();
catch
WriteLocalLog("Checking current loaded inspection path is fail. " + VBAIEnginePath + " VBStatus=" + VBStatus.ToString(), true);
return 1;
if (VBAIEnginePath != ActualInspectionInfo.path)
WriteLocalLog("Actual opened path is different or no opened inspection. " + "VBStatus=" + VBStatus.ToString(), false);
if (System.IO.File.Exists(VBAIEnginePath))
try
WriteLocalLog("Setting rider's combo box to last selected item... " + "VBStatus=" + VBStatus.ToString(), false);
engine.OpenInspection(VBAIEnginePath);
return 0;
catch
WriteLocalLog("Can't open the inspection, named: " + VBAIEnginePath + " VBStatus=" + VBStatus.ToString(), true);
return 2;
else
WriteLocalLog("Inspection does not exists. " + "VBStatus=" + VBStatus.ToString(), true);
return 9;
return 0;
(1,224 Views)
