Machine Vision
VDM2011 is included in VAS2011 ?
I install VAS2011 in CVI2010 environment,I found CVI to increase the NI-IMAQ functions and the VDM Vision function,
The full functions of the VDM2011 included in VAS2011? Whether to install VAS2011 do not need to install VDM2011?
I do not need the Vision Assistant of VDM
thanks!
(3,676 Views)
Hi
If am not wrong its exactly reverse as you said VAS2011 included in VDM2011 - out off topic
No, Contains basic functions related to interfacing camera with labview.
No not needed, you can install it separately.
Hope answered your question.
Silver_Shaper | CLD
(3,675 Views)
I is to install VAS2011 in labwindows,The full functions of the VDM2011 is include in VAS2011,do not?
I only installed the VAS2011,Have seen a lot of the VDM library function
Seems to be complete.
(3,668 Views)
I think it is shown because the function palette doesn't reflect current license status like LabVIEW does. If you call functions that require a VDM license you will likely get an error that your license is not activated. The basic image functions should work without a VDM license though. Eric
(3,653 Views)
