03-21-2008 12:35 PM
03-24-2008 06:18 PM
09-21-2010 06:13 AM
Hello, I have a working Flea2 CCD camera and a working Labview program to use it. The problem is that I cannot make the the camera to appear in the MAX. It would be very usefull for me if someone writes down several steps how to make the three things (PC, Flea2 firewire camera and a functioning Labview program for it) work together. Thank you!
09-22-2010 10:50 AM
Hi Peter,
Do you have the IMAQdx driver installed on your system? To use a Firewire camera with MAX and LabVIEW you need the IMAQdx drivers. You can get this driver by installing the Vision Acquisition Software.
Thanks and have a great day.
09-23-2010 10:11 AM
I used firepro driver by the instalation of the camera - that's why it was not appearing in the device manager and MAX. I have IMAQdx and I managed to run the camera. The next goal is to conver the live video stream to a Intensity matrix so I can fit later.
Thanks for the reply and if you have some suggestions on the new goal please dont hesitate and let me know.
Cheers!
09-24-2010 10:55 AM
09-28-2010 08:38 AM
Hi I now know that there is a example.vi(Image to array) that is doing that. I dont have it even though I have the Vision Development Module.
Could you please upload it.
Peter
09-29-2010 12:18 PM
Hi Peter,
I am sure it should be installed with the VDM. Go ahead and search for it in LV see if you can find it.
10-05-2010 07:06 AM
You were wright it was there. Find example didnt find it but manual seach helped.
10-05-2010 07:07 AM
Many thanks!!!!
