Machine Vision
VISION BUILDER FOR AUTOMATED INSPECTION
I'm doing a program for a vision machine with NI Vision Builder and i want to know how l could make the counter of #Pass and #Fail in the interface of inspection work automatically ?
Message 1 of 15
(6,045 Views)
Hello nouva,
Not sure if I understood your question. The inspection interface shows by default the number of Passes and Fails when you run it continuously.
Would you please add more details on what you want to accomplish?
AGJ
Message 2 of 15
(6,015 Views)
send your file I try to fix it
Message 3 of 15
(5,977 Views)
For Vision Builder AI to count the number of pass/fail, you must insert a Set Inspection Status step in your inspection.
Hope this helps,
-Christophe
Message 4 of 15
(5,949 Views)
Thanks for your attention.
I have another problem : i try to generet labview code from the code that i have develop with Vision Builder 2013  but it asks me to install Labview and vision development module  2012 or later although i have installed the 2 of them it doesn't work .
I would ask you if there is a solution for this problem ?
Message 5 of 15
(5,933 Views)
Message 6 of 15
(5,928 Views)
Message 7 of 15
(5,927 Views)
Message 8 of 15
(5,926 Views)
Nouva,
Could you please add screenshots of NI MAX showing the versions that you have installed for Vision Builder, LabVIEW, and Vision Development Module?
AGJ
Message 9 of 15
(5,907 Views)
Hi ,
you will find 3 screenshots of the labview,Vision Builder and vision devlopment.
thanks
Message 10 of 15
(5,849 Views)
