Machine Vision
VISION- displays picture before threesold
Hi
I have simple problem I quess
I `ve got simple basic program e.g grab .vi and in addition there is threshold function. I`d like to displays images gathered from camera before and after threesold function. It seems to work in debug mode only. Flat sequence deosn work either. Maybe refernces have something to do with that but I dont know how
(3,864 Views)
I haven't looked at your code.
For this, you must have two images:
(1) for the image as it came from the camera.
(2) a copy that you pass to the threshold function.
Then you can use two Image Displays to show these images.
(3,861 Views)
If you're like me you're a visual learner, so here's a picture.  (There's also a shipping example in LabVIEW called Threshold Example.vi, but it's not for beginners.)
Vision and Motion Enthusiast
Certified LabVIEW Associate Developer
(3,841 Views)
Almost perfect: Do not call "IMAQ Dispose" as long as you need an image (even in an IMAGE Display indicator).
As you have not wired an image to "IMAQ Dispose", no image gets disposed.
(3,834 Views)
GuenterMueller,
Good catch!  I want to amend your statement just a bit though.  We should always call IMAQ Dispose any time we call IMAQ Create (once we're done processing of course.)  Otherwise the image reference remains in memory until we quit LabVIEW.  If we want the image to remain in the indicator after the program finishes we have to right click on the indicator and choose Snapshot.  This keeps the current image in the indicator until a new image is sent to it.  You're absolutely correct though that in my example the image reference never actually gets disposed.  We would either have to wire the image reference to the dispose VI, or wire a true constant to the dispose all input.  Thanks for catching this.
(3,816 Views)
