Machine Vision
Verify dot mark presense and absence at defined location
I am having a difficult time finding a way in vision to verify the presense and absense of dot mark in the image at defined location.  I am attaching image.
  Can anyone help?
software Vision 7.1
Attached images have dot at different location.
(3,450 Views)
Your dot marks can hardly be seen (it took me a while myself to find it). Can you enhance the image (contrast enhancement) before thresholding the image using red plane exraction.
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(3,431 Views)
Thanks you
I tried enhancing the image but no result from it. In thresholding the whole surface looks similar and could not able to extract the dot .
 help me to verify the presence and absence of dot.
 attached image is the red plane extracted image.
(3,394 Views)
