Machine Vision
Vibrometer
HI All,
Plz, I am looking for LabVIEW drivers for a polytec scanning laser vibrometer (using NI-5133) and
a Physik Instrumente (PI) 2-axes motor (with PI C-863 motor controller) system.
This system have to be able to perform scanning at defined intervals and
record the frequencies and amplitudes (data acquired) at each point.
I do have NI-Scope and some VIs from PI for C-863
But can NOT synchronize the motion and acquire data as defined above.
Cheers
(4,103 Views)
This may not be the best area to post this, you posted in the machine vision section (perhaps by mistake...).
Good luck with your application!
-Matt at Cyth Systems
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(4,093 Views)
Hi Koye88,
Thank you for contacting National Instruments. Please refrain from posting the same issue many times as this will spread the effort in trying to help you with your application. I am going to recommend that users reply to the forum you posted under real-time rather than this thread.
Duplicate thread
Many thanks,
Andrew McLennan
(4,070 Views)
