Machine Vision
Viewing mist vapour
I am not sure if this is the right forum for this sort of question.
I am intrested in looking at vapour particles in mist generatred by piezo crystal which vibrating a metal plate with some water on top of it.
But I am difficultity lighting the mist so that the camera that I am using it picks sees it.
I am using this camera http://www.avsupply.com/details/cvm532.shtml and a PCI-1405 framegraber PCI board.
What steps could I take to successfully light it?
Many thanks,
Jack
(3,953 Views)
You might try the Schlieren technique to image the water vapor, see http://forums.ni.com/t5/forums/replypage/board-id/200/message-id/23112 for an explanation.
Robert Eastlund
Graftek Imaging, Inc.
Phone: (512) 416-1099 x101
Email: eastlund@graftek.com
(3,951 Views)
Robert:
Your link comes up as a reply to this thread. Insert own solution here 🙂
-AK2DM
(3,945 Views)
Here is the correct link:
http://en.wikipedia.org/wiki/Schlieren_photography
Robert Eastlund
(3,941 Views)
I would consider coloring the water so it is not completely transparent.  I would suspect side lighting (dark field illumination) would likely work well with a dark background.
Bruce
Bruce Ammons
Ammons Engineering
(3,920 Views)
