Machine Vision
Visiion assistant wont generate VI
I have recently upgraded to Vision assistant 2020. When I try and generate a VI for my script I get errors because the program can't locate niRio_Find Devices.vi  and another Rio related vi. Not seen this kind of problem before with vision assistant. Does anyone know where these files might be located?.
(2,570 Views)
Install the RIO driver. This should fix this issue.
(2,544 Views)
I suspect you are probably right. I tried downloading the RIO drivers but my PC hard drive was full, so no chance to test as yet.
I don't use RIO and don't recall downloading the drivers before. Never had a problem until v2020. It's a pity because the code generation feature in Vision Assistant is extremely  useful.
Thanks for the reply.
(2,497 Views)
Had the same issue. Downloading CompactRIO fixed it!
Thank you 🙂
(2,439 Views)
