Machine Vision
Vision Acquisition of webcam on LabView
Hi, I'm using NI LabView 2009 with Windows 7 as my OS.  I have a simple question, I just want the vision acquired from my webcam on the LabView. I googled piles of codes and they all show that there used to be an USB webcam version of icons which I believe they are not used in LabView 2009 anymore.  Will you show me the block diagram?
(5,166 Views)
Hi Ray Lim,
You can take a look IMAQ for USB for labVIEW 8.6 in this link:
http://zone.ni.com/devzone/cda/epd/p/id/5030
To use them in labVIEW 2009, you can use the upgrade IMAQ for USB to labVIEW 2009 utility in this link:
https://forums.ni.com/t5/Archive-TKB/Upgrade-IMAQ-for-USB-to-LabVIEW-2009/ta-p/3497557
I hope that this helps and don't forget to kudo if it is.
- Meadow -
LabVIEW 7.0 - 2011, Vision, RT, FPGA
TestStand 3.0 - 4.5
(5,148 Views)
In this example, we will create a program in Labview to capture images from a USB camera to your application for further processing using the NI Vision module.
https://decibel.ni.com/content/docs/DOC-30531
(4,076 Views)
