Machine Vision
Vision Assistant Caliper Results Accuracy
I would like to increase the accuracy of the results that are yielded by
the caliper function using Vision Assistant 8.6. I think this might just
be a formatting issue, but right now the most number of decimal points
that I can see for values calcuated using the Caliper tool is two. Could
someone please tell me how to increase the number of decimal points?
Thank you very much!
Austin
(3,769 Views)
Hi Excalibur33,
Have you calibrated the caliper function (in what unit does it report the results)?
Joe Daily
may the G be with you ....
(3,760 Views)
Joe,
Yes, I calibrated the caliper function so the measurements it produces are in inches.
Austin
(3,757 Views)
Hi Austin,
that output is fixed in it precision. You can work around this in one of two ways
  • Migrate the code to labview and then you will have access to the full data.
  • Leave the calibration in pixels (assuming that you have more than 1 pixel per inch)
Joe Daily
(3,744 Views)
Joe,
Ok, I was starting to get the feeling that that might be the case.
Thank you very much for your help!
Austin
(3,740 Views)
