Machine Vision
Vision Assistant Crash when selecting an avi file.
When i click Open an Avi file and select the folder that contains the avi file (vision examples folder). Vision assistant crashes
Anyone knows why this can happen.
(3,267 Views)
Which version of Vision Assistant? I can't reproduce the crash.
Thanks.
(3,255 Views)
2018 32b.
it is getting me crazy. Also, when i run the example Read avi file.vi it crash when it gets to IMAq avi2 Open function.
(3,249 Views)
I am not surprised. Vision Assistant is calling the same function. Could you please attach the crash dump?
(3,229 Views)
it does not generate a crash log. VA closed without reporting an error. i think it has something to do with the type of avi.
Using an old avi writeandread vi example, i creted an .avi file using my latop camera.
i did not have a problem accesing this file from Visual assistant..
so i am guessing that for some reason using the .avi in the vision example folders is what is causing the crash.
codec problem??
thanks
(3,208 Views)
