Machine Vision
Vision Assistant Help: How do I keep particles that match a shape?
I'm using the shape match (binary image) tool in Vision Assistant to sift some particles out of a large number of them. The shape match works well, but I can't seem to move those results into another block of the Vision Assistant script.
How do I pass the particles that match on to another block? Or discard all the particles that don't match?
(3,079 Views)
Actually, there is not a way to pass only the shape match results onto another step in Vision Assistant. The one exception to this is the Caliper step, which can use the shape matching information.
What are you trying to accomplish? Perhaps we can work around this issue another way.
Dawna P.
(3,079 Views)
