Machine Vision
Vision Assistant OCR tool
I am trying to read labels and some of the text is encroaching on neighboring characters.  For example, I have to "-V" but the "-" is withn the footprint of the "V" so OCR sees it as one character.
How do I get around this?
Thanks for the help!
Message 1 of 8
(4,406 Views)
Additional info; results from IMAQ Read Text 4:
Output string = 462-9103-V1-     Length = 12 (which I would expect)
Character Report only has 11 characters.  The 8th character is "-V"
In other words the VI Output string is not the same as the Character report output.
Message 2 of 8
(4,373 Views)
Try turning Auto Split on.  This will separate overlapping characters, according to the manual.
Bruce
Bruce Ammons
Ammons Engineering
Message 3 of 8
(4,368 Views)
Thanks, I'll give it a shot.  Still don't understand why the 2 outputs from one VI aren't consistent though.
Message 4 of 8
(4,366 Views)
Tried it but it didn't help.  Maybe I set it up wrong?!
Message 5 of 8
(4,131 Views)
Can you add the - as a trained character? If so and they are identified as unique entities can you just parse them out of your data?
-AK2DM
Message 6 of 8
(4,084 Views)
Thanks for the suggestion, but the "-" is already trained AND being picked up twice (2 out of 3 occurrences) in the same inspection.  If you look at the length of the output string there are 12 characters, which is correct (9 alpha numeric and 3 “-“).  But if you look at the size of the character report, it is only 11.
Message 7 of 8
(4,081 Views)
Sorry, looking at the image closer I now see the red borders around the -.
Not sure about the count discrepancy, I have only dabbled in OCR with no deployed programs.
-AK2DM
Message 8 of 8
(4,076 Views)
