Machine Vision
Vision Builder AI - Different Exposure and Different Frame Size
Is it possible to have different exposure times and frame sizes with a line scan camera, basler racer, in different steps.
I want to trigger in the first step with the next step. In the first the the camera make 37 frames per second. The frame size is 6144 x 256 px.
in the second step I want to do a measurement. The camera should make 1 frame per second. and the size is 6144 x 4726.
Is there any possibility to solve this problem?
(4,927 Views)
Which interface are you using : GigE or CameraLink ?
Sami Fathallah
ALLIANCE VISION
HW and SW Components for Scientific Imaging and Machine Vision
http://www.alliancevision.com
(4,921 Views)
GigE
(4,903 Views)
If you are using VBAI with a GigE camera, I think you might be able to do this with the Read/Write Camera Attributes in the Acquired Images tab.
(4,795 Views)
