Machine Vision
Vision Builder AI Vision Assistant issue with smart camera contrast
I am using a NI 1776C smart camera with Vision Builder AI 2011.  The contrast is pictures in different from automated mode and running on the PC.  After using vision assisant to process an image (erode, color threshold, lookup), when I run this script from the pc I get a totally different contrast then when I save the script to the smart camera and run in auto mode.  Not sure why this is happnening.
(4,392 Views)
Did you change any of the camera settings in MAX when testing on the PC? Any change in lighting between the two? Would you post sample images please?
(4,275 Views)
