Machine Vision
Vision Builder AI and multiple cameras/image files
We are trying to develop an inspection using Vision Builder for AI with 3 1394 cameras.
We have setup the image output to save all images from the inspection, however it only saves the last image acquired during the inspection.
Is it possible to have Vision Builder save the images from the other 2 cameras?
(3,171 Views)
VBAI only has the ability to save the last image. If you would like to save the other images you will need to port the inspection to LabVIEW, and use Vision to save the other images. The other option is to create inspection scripts for each of the cameras.
(3,171 Views)
