Machine Vision
Vision Run Time and imaq1394.dll not available error
I have installed vision run time and am trying to run a compiled application.  The application will not load completely due to absence of imaq1394.dll.  I was told by sales that this is included in the run time licence.  Is this not the case?  What else could be causing this issue?  Thank you.
(4,168 Views)
Gene,
If you are using a FireWire camera, then you will need to install the IMAQdx drivers in addition to the Vision Run-time engine.  This is not included with the run-time.  The run-time engine is for executables that use functions from the Vision Development Module, which is for processing images.  Sorry for the inconvenience.
Is your application just acquiring the images, or is it also doing processing?
-Christina
(4,145 Views)
Christina,
I am using a FireWire camera and I will be doing processing.  I also have LabView 8.6 debugger installed.  Is it then correct that the debugger does not have the IMAQdx drivers also?  Does the professional LabView 8.6 have these drivers or do I have to spring for an additional $300+ for these?  Thank you for your assistance.
(4,137 Views)
Gene,
The IMAQdx drivers come with the Vision Acquisition software package.   This comes with the Vision Development Module, which is used for image processing.  Are you only planning to run existing code, or will you be editing the code at all (or wanting to write new code)?  If you are only running existing code, then you will need the Vision Run-Time Engine and the IMAQdx drivers on each computer that will be running the code.  If you will be developing code, you will need the Vision Development Module (which comes with the drivers) on any computer where you will be editing code.  Take a look at this KnowledgeBase article for more information.
-Christina
(4,132 Views)
