Machine Vision
Vision Runtime and NI TestStand
I have installed Teststand and LabVIEW in my PC. I have no Vision Development Module in the PC, but using Vision runtime engine and changing TestStand adaptor to “LV RunTime”, is it possible to run the TestStand sequence with LabVIEW Vision Vis ( IMAQ create, IMAQ dispose etc. Sub VIs)?
(4,517 Views)
It is a couple of years ago that I have been doing so. It should work as described here.
(4,354 Views)
