Machine Vision
Vision acquisition
Hello all I need your help because I have problem with the option vision acquisition in labview it worked well some days ago but right now can't open the window to select the camera there I want to choose, missing some libraries or something like that.
Thank you
Regards.
(3,619 Views)
Hi Germain.
Could you post the error you're getting? Did anything change on your system (Uninstalled something, updated something, etc.)?
When you say you can't open the window to select the camera, which window do you mean exactly? Is it a Vision Acquisition Express VI or an application you already have written?
Regards.
Aldo H
Ingenieria de Aplicaciones
(3,604 Views)
