Machine Vision
Vision assistant missing .llb (ver 8.6)
Attempting to build a VI using Vision Assistant 8.6.  Using the Shape Detection tool as well.  When building the vi, it is looking for Vision Assistant Utils.llb (IVA Store Shape Circles Results.vi).  I cannot locate it anywhere on my harddrive.
Message 1 of 11
(6,345 Views)
Do you have a full version?
Message 2 of 11
(6,320 Views)
C:\Program Files\National Instruments\Vision Assistant 8.6\CG\IVA Templates LV8.6-Visionxx.llb.Dont you have this llb?
Message 3 of 11
(6,318 Views)
IVA Store Shape Circles Results located in <Program Files>\National Instruments\LabVIEW 8.6\vi.lib\vision\Vistion Assistant Utils.llb.
If this llb not present, I will recommend to reinstall Vision Assistant (or Vision Toolkit completely).
Andrey.
Message 4 of 11
(6,315 Views)
It is still missing after reinstallation of VA and Vision 8.6
Message 5 of 11
(6,151 Views)
Message 6 of 11
(6,150 Views)
Hi MSE
From reading this thread it appears that the original issue faced by dre99gsx was resolved by reinstalling Vision Acquisition Software. I take it you are experiencing a similar problem when creating an application using application builder you run into this missing dependency? Are you using both Vision Development Module and Vision Acquisition Software? Are both of these activated?
Thank You
Eric Reid
Motion R&D
Message 7 of 11
(6,118 Views)
Sorry for the delay.
I reinstalled the complete Vision Assistant.  I did have two versions 8.5 and 8.6.  Somehow, it didn't install all the components thinking 8.5 had them installed (I didn't do a full 8.5 installation).  I removed them all and reinstalled 8.6 completely.  Problem fixed.
Message 8 of 11
(6,112 Views)
Reinstall did not work. I installed fresh LV 8.6 and 8.6 Vision from the 8.6 DVD on to another computer and it did.  Problem is unresolved, but I have just copied it from my new installed PC directory to my other 2 dev machines.
Message 9 of 11
(6,087 Views)
Hi MSE
Sounds like not all the components were removed during the reinstall, we can assume the disks have not been damaged since you were able to install on the fresh PC. Was the work around of copying the library files across from the fresh machine to the other PC's successful?
Thank You
Eric Reid
Motion R&D
Message 10 of 11
(6,078 Views)
