Machine Vision
Vision assistant script
May i read the parameters in  a vision assistant script in LabVIEW enviroment?   I know vision assistant can generate LabVIEW code, and so i can get the parameters futhermore. But if i use the code as a subvi, i must rewrite the vi when the prameters changed.
Thanks.
(3,476 Views)
Generating LabVIEW code is right now the only way to migrate from a Vision Assistant Script to LabVIEW.
Vision Assistant create constants for the parameters, but you can change them to controls and connect them to the connector pane when you create your LabVIEW sub-vi.
Christophe Caltagirone
IMAQ R&D
(3,435 Views)
