Machine Vision
Vision builder AI running Ethernet IP server on my computer
I am running Vision bulider AI on my computer and I need to exchange data thru the Ethernet/IP protocol.
In vision bulider I have startet the Ethernet/IP server.
I am using a Devicenet to Ethernet IP gateway from Hilscher, When I go online on this device I see that it can not see any slaves.
Using wireshark I can also see that the gateway is actually trying to establish communication.
How can I see which NIC VBAI is trying to establish communication thru?
Is this type of communication only possible on a smart camera?
Johan
(5,330 Views)
Hi Johan,
Could you please provide some more information on your setup, model number on the Hilscher device etc. Are you for instance running Vision Builder AI on a computer with multiple network cards?
Have you tried connecting to your device using MAX?
Have you gone through a setup process similar to this one?
Setting up Implicit Ethernet/IP messaging between an Omron PLC and Vision Builder AI
http://www.ni.com/white-paper/13579/en/
Robert P-F
(5,248 Views)
The communication works now, but I am having problems seeing where the problem was. If I can figure it out I will post it here.
Johan
(5,143 Views)
