Machine Vision
Vision camera for extended temperature operation
I need to be able to verify the operation of a display while a unit is being thermally cycled. Temperature ranges are -40C to +85C.
Thought about using some optice to send the image outside of the chamber, but this makes the lighting more complicated.
Is there a series of a cameras that would support this type of operation?
(5,133 Views)
This is not an answer to your question, but something you have to be careful about is the convection in the heated air of the chamber moving air of differing densities between your camera and your display.  This is the effect you get looking down a hot road in the summer or looking just over a fire.  Normally it is not noticable at these fairly reasonable temps, but it could be a problem if you are looking for single pixel accuracy.
Also, you will generate frost on the camera at low temps and have it melting when transitioning to higher ones.  This can be a problem as well (ask you probably know).
As for the camera to use, I am at a loss.  The cameras I have used in the past all have specs that limit the max temp to a lower limit.
Sorry,
Bob
(5,133 Views)
Hello James,
I am not aware of any cameras that will function within that temperature range.  I would suggest that you try contacting different camera manufacturers.  I have provided links to several camera manufacturer websites.  Try contacting them to find out if they offer any products that will operate within that temperature range.
Redlake
Dalsa
Basler
JAI
Cohu
Hamamatsu
Sony
Scott R.
Scott Romine
Course Development Engineer
(5,110 Views)
Reviving an old post....
Has anyone come across any wide temperature range cameras?  I have a very similar application problem.  I thought about using some sort of enclosure to keep the elements out, however I would like to eliminate any additional glare that may introduce.  Thanks for any help.
Nick
(4,878 Views)
Hi Nick,
The geometric matching algorithm can compensate to some degree to reduce non-uniform lighting (shadows, glare and light drifts) on objects. For a Camera I would recommend looking at the list Scott provided above. An enclosure would be another way to accomplish this as well.
Thank You,
Eric Reid
Thank You
Eric Reid
Motion R&D
(4,826 Views)
