Machine Vision
Vision dotNet function reference
I am using NI Vision development module with Visual Studio C# Express and I can't find the Help for the dotNet classes. Does anybody know how to install and access this help file or if there is an on line version of it?
Massimo
(3,960 Views)
You will find the answer on your installation disk:  Open the readme.html. Check the paragraph "NI Vision for .NET Documentation".
It depends on the version of Visual Studio you are using and the version of the Vision Development Module that you have.
Good luck.
(3,947 Views)
