Machine Vision
Vision installation after upgrade to LabView 7.1
Hello!
I had the LabView 7.0 and the Vision module (Windosw XP). Everything worked fine. Recently I upgraded to Labview 7.1 and now I would like to know what should I do with Vision? Do I need to install it again? Activate?  Please help. Thanks.
Pavel
(2,901 Views)
You should just need to add support for the new LabVIEW.  Repeat the installation process, and make sure you go to the custom installation where you can pick what is installed.  Select support for the new LabVIEW, and start the installation.  It should be pretty quick.
Bruce
Bruce Ammons
Ammons Engineering
(2,898 Views)
